system exec call question
I have a vi that I want to call another executable (i.e. excel) using the
system exec.vi. I want to run the called application in the background in
parallel with my vi. When I tried this, I wasnt able to operate my vi, buttons
pressed but there was no resulting action. i assume its because the other
application had control. any suggestions?
chuck
(3,321 Views)
I hate to ask the obvious question, but did you have the wait until completion set to False? If true, that would have stalled that data flow until the called application completes.
Stu
(3,321 Views)
Stu wrote:
>I hate to ask the obvious question, but did you have the wait until>completion
set to False? If true, that would have stalled that data>flow until the
called application completes.>Stu
Stu,
I am probably missing something simple, but I am not sure where you set the
'wait until completion'. also, I have tried using system exec.vi to call
both a program that I had built using labview, and also commercial programs
(i.e. photoshop)just to see if it was my program at fault. Both situations
resulted in a hangup.
chuck
(3,321 Views)
"chuck" wrote:
>>Stu wrote:>>I hate to ask the obvious question, but did you
have the wait until>completion>set to False? If true, that would have stalled
that data>flow until the>called application completes.>Stu>>Stu,>>I am probably
missing something simple, but I am not sure where you set the>'wait until
completion'. also, I have tried using system exec.vi to call>both a program
that I had built using labview, and also commercial programs>(i.e. photoshop)just
to see if it was my program at fault. Both situations>resulted in a hangup.>>chuck
stu,
thanks, that was it. On the system exec.vi from labview 5 there wasn't an
input for 'wait until completion', but I see it on the labview 6 version.
thanks for the help.
chu
ck
(3,321 Views)
Hi chuck,
for a better dataflow between your vi and Excel you could use an ActiveX
object. With it you have direct access to all features of Excel.
Henrik
> chuck
(3,321 Views)
