system exec.vi出现buffer overrun detected!
I use system exec.vi to call an exe program, but it always promp a error " buffer overrun detected!". At first i though 4096 is too small, so i changed it to 40960. The problem still exist. The commad is "path\chooch.exe -e Se -a K filename", chooch.exe is the execute file, and -e, -a is the option. Any suggestion and comments welcom!
(2,795 Views)
What does a buffer have to do with the System Exec VI?  Where are you changing a value from 4096 to 40960?
(2,786 Views)
Does that command work for the DOS prompt?
I think I saw that message when I passe a bad command.
Just trying to help,
Ben
(2,763 Views)
