system exec.vi mysql
Hi
Any idea how I can use system exec.vi to run mySQL syntax becos I wanted to get raw values as using ADO alter the values. For example, I read in mySQL that showed me null and 0.0 values. After ADO, it reads out 0.00 and 0 instead and I am feeling frustrated. Why can't the values be same through ADO as in mySQL. That's why I am thinking of using system exec.vi to do mysql syntax to get correct values.
Please advise how i can do that.
Thanks in advance.
I am using Labview 7.1, LABSQL(ADO) and ADO Toolkit
Clement
(3,332 Views)
This is ADO problem.
I think that would be difficult to solve it with system exec.
Instead of doing so, I'd recommend you to use replace string function to replace 0.00 with null.
That's a lot easier.
(3,301 Views)
Hi Kate.
Thanks for your help. It turns out it's the datatype " decimal"  in mysql.
Using decimal datatype, null and 0.00 value will produce 0 which is not desired.
So I changed it to float datatype and null and 0.00 value produce null and 0 value that I am able to make differentiate.
However, what 's the difference decimal and float datatypes?
I have read and it has to do with evaluation within mysql environment but my application does not require. So it runs smoothly. and it works perfectly.
Smiley Wink
regatrds
Clement
(3,263 Views)
