t0 the trigger point in a waveform -- not a timestamp
Build Waveform  t0  is a timestamp.  How do I set the trigger point of the waveform graph (t0)?  To the right of t0 is positive time, the left is negitive time.  I am plotting oscilloscope waveforms.
thanks , rh
(2,650 Views)
You don't have to use Build Waveform. You can just use the regular bundle function. Turn on context help and move your mouse over the graph's terminal on the block diagram. An example is shown there where the first element is x0 (a numeric), the second element is delta x (also a numeric), and the third element is the y array.
(2,640 Views)
(2,629 Views)
