tab control defaults to wrong case
I'm using a tab control inside my outer While loop to select different cases. (A user click on a tab selects that case and runs the appropriate code.) When I first load the program it opens at a case that I don't want until later in a series of user interactions.
I've made my preferred case the default but the program doesn't open up in that tab. Why not? What am I missing?
(3,124 Views)
Are you able to post a snippet of code that shows this behavior?  I don't see this behavior in a small VI I made based on your description.
-Steve
(3,111 Views)
Well I figured out what I was doing wrong. Are you ready for this? It's kinda complex...
You know how on the front panel you can right click on a control to pull up a menu.. then select Data Operations and Make Current Value Default ...?
Boy, do I feel dumb!
(3,074 Views)
When you wrote, "I've made my preferred case the default" I assumed you'd already done that.  Good job for figuring it out.
-Steve
(3,063 Views)
