tab control--how do I use same control/indicator on multiple pages.
Actually that plan worked out. The trick for me as a noob was placing my copying code inside the appropriate event structure.
I found there is an event for Tab Control - Value Change. I made 2 event dependent cases to match the 2 tabs with the controls I want to manage ( Read & Write Serial). I placed property value copy commands from Control 1 to Control 2 inside the event structure when the tab control value becomes a new value of "Read" and copy commands for Control 2 to Control 1 when the tab control value becomes a new value of "Write".
A picture can tell up to a thousand words - here's one:
Hope that helps,
Chris
Message 11 of 13
(2,943 Views)
Hope that helps,
Chris
Very cool.  I'm glad you found your path forward.  🙂
Bill
CLD
(Mid-Level minion.)
Message 12 of 13
(2,927 Views)
Hope that helps,
Chris
Locals are more efficient than Value Properties, so if you're going to go that route, I'd use locals.
What I'd really do though is use nathand's approach.
Tim Elsey
Certified LabVIEW Architect
Message 13 of 13
(2,902 Views)
