tab control: how to retrieve text of currently selected tab
In a Ring Control I simply create a property node to bring up the Strings[] property, and use the ring control as an index to select the correct string.
I can't seem to find anything similar in the Tab Control.
So .. how does one retreive the text of a currently selected tab in a Tab Control?
Thanks!
(3,495 Views)
Actually, with a ring control you don't even need to do all that. You can just use the RingText.Text property.
For the tab control: A tab control is an enum, so you can just use the Format Into String to get the text of the page:
Message Edited by smercurio_fc on 05-21-2009 03:54 PM
(3,491 Views)
You could just format it as a string as follows:
(EDIT: I see smercurio was faster. Somebody distracted me while I was editing..... ;))
Message Edited by altenbach on 05-21-2009 02:00 PM
(3,487 Views)
THANKYOU!
(3,481 Views)
Yeah, it was me, telepathically. Smiley Very Happy
(3,479 Views)
