tab control page visibility problem
Hi, ALL:
I'm new to LabView, using 7.0
In the attached code, I want to control the visibility of Tab pages. There is a problem, page 1 is still visible when it should be invisible although it is dark. How to solve this problem?
Any comment is appreciated.
boardkey
帖子被boardkey在12-06-2005 09:59 PM时编辑过了
(3,403 Views)
Hi Broadkey,
Look at attached VI,
After you set a page as visible, just assign the tab value to point to that page(using a property node of tab)
It will work as desired.
Regards
Dev
(3,386 Views)
Hi boardkey
The simplest and complete method i could think was this.(look at attached VI)
regards
behzad
(3,384 Views)
Hi, Dev and Behzad:
Thank you.
Behzad's method works, and it is decent.
Sorry, Dev, I cannot open your VI because it is 7.1. ( I guess this is LabView's big problem.)
I'll keep on working.
best regards,
boardkey
(3,378 Views)
Hi Broadkey,
good to hear that your problem is solved.
Just for interest, posting my solution in LabVIEW 7.0
Regards
Dev
(3,374 Views)
