tab control usiong tool bar
Hi!
In my application i want show different graphs using tab control.How can i control the page selection  of tab cntrl.  using different buttons that i put up on my tool bar.Is there any property to this op.?
DeWalker
(3,154 Views)
hi
what type of tool bar u r using better send screen shot of u r application Front panel with explanation
Santhosh M
(3,145 Views)
Accepted by topic author DeWalker
Create a local variable of the tab control and wire a constant into it. Run this code when your button is pressed.
The downside of this is that if you are reading the value of the tab control as well, it will break dataflow and cause a race condition.
_____________________________
- Cheers, Ed
(3,141 Views)
Hey !
Ed, thanks .Such a simple solution.
Cheers
(3,090 Views)
