tab control with a case structure
I am having trouble getting my tab control to work with case structure. I have 4 tabs that i want displayed on my front panel, each with a separate graph. When I click on any tab besides the first one there is nothing shown on the graph. I think i have some wiring issues. Any ideas?
Message 1 of 8
(5,906 Views)
Merging the tab control with the signals and then wiring that to a case statement makes absolutely no sense. Trying to wire the case selector boolean to a graph makes even less sense.
Do not merge the tab control with anything. Do not place case statements inside your outer case statement. Just place the graph inside the outer case statement and wire the signal to it.
Message 2 of 8
(5,896 Views)
I don't think you need the inner case structures or the merge signal functions.  The way you have it wired, you will have to click on the correct tab BEFORE you run the program.  This is because you are only populating one graph due to your case structure being wired to the tab selector.
Alternately, you could eliminate the outer case structure and populate all the graphs, then just click on the tab of your choice to see each graph.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 8
(5,893 Views)
Interesting VI. But, what do want to do?
Christian
Message 4 of 8
(5,892 Views)
The whole ting seems to be infected by a bad case of the "express VI abuse" syndrome. Smiley Very Happy
Message Edited by t06afre on 04-20-2009 05:20 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 8
(5,886 Views)
how would i go about doing that?
Message 6 of 8
(5,879 Views)
Make your block diagram look like this:
Message 7 of 8
(5,861 Views)
See also this and this discusion. Most of the time, tab controls don't need any code. 😄
(You also have a couple of breakpoints (one on the entire diagram and one on the while loop). Make sure you remove them. Look for the red outlines.
Message 8 of 8
(5,836 Views)
