tab control with events
I've done some searching to find a solution to my issue, but haven't found anything.
I'm using Tab Control. After some intialization a while loop is entered. Within the while loop is a case structure with the tab control enum wired to the selector terminal.
Here's the problem (I think). Each case (tab) has an event handler in it. The event handler serves a boolean.
When the VI is run and I change tabs, the application locks up. Highlighting execution doesn't help much.
When the VI is run and tabs are NOT changed, the exit button works as expected.
I think I'm missing a basic rule when using events and the tab control.
Your help will be appreciated.
todd
(2,778 Views)
The on-line help has a subject called "Caveats and Recommendations when Using Events in LabVIEW". In there, it recomends not placing more than one event structures in a single loop. All of your event structures are active and must handle an event for the loop to reiterate. Placing all events in a single event structure should fix the problem.
(2,768 Views)
