table and listbox problem
hello, i'm a student and i'm approching labview since few months,,,,
i have this problem:
i need to write some data in a table or in a multicolum listbox, but i see only a part of my data. sometimes some box are empty.
searching the mistake i saw that the same data flow linked to an array results correct, all boxes are full of my data...
In what way can i resolve this problem?
PS: my data are long string
thanks
Using LabVIEW 7.1
Message 1 of 10
(5,131 Views)
It would be better if you can post the actual vi.
Message 2 of 10
(5,117 Views)
i send you this...it's difficult send you all....are many subvi 🙂
Using LabVIEW 7.1
Message 3 of 10
(5,111 Views)
That doesn't really do us any good since there is no front panel to show the problem. I'm going to assume your string is too long for the current column width. You can hover over the column separator to get the "move" cursor and drag the column as wide as you need:
String too long for column width:
string now shown after moving column separator:
Message 4 of 10
(5,102 Views)
no 😞 my problem is different...you can see it from my image in first attachment 😞
the 4° column sometimes is empty (for example at time 23.075230)...instead i should have something in it as you can see from array 😞
when in the 3° colums is written FC is normal that the 4° one is empty 😛
Using LabVIEW 7.1
Message 5 of 10
(5,094 Views)
All you need is attach the toplevel VI you are showing in the picture. Make sure all controls and indicators contain the data shown, then make current values the default. Save the VI under a new name and attach it here.
Pictures are pretty useless!
Message 6 of 10
(5,085 Views)
I can't make out enough detail in the PDF to be of any help. Sorry.
Message 7 of 10
(5,084 Views)
It is possible that your fields have long trailing blanks and the tables are right-aligned while the array is left-aligned. Check the text justification settings.
What happens if you click in one of the seemingly empty fields?
Message 8 of 10
(5,075 Views)
solved....my data was too long for listboxes and tables
thanks anyway
Using LabVIEW 7.1
Message 9 of 10
(5,068 Views)
Sooo... how long was your data? Is thre a documented maximum field size?
Message 10 of 10
(5,054 Views)
