table cell color
I have a VI that fills in color for certain cells in a table under certain conditions. But when I call this VI in another VI, and create an indicator, I just get a regular table, not one with background color fill in. Any idea? How do I make it so that I can call this VI and get color fill in? Thanks.
(3,328 Views)
When you create the indicator for the output from the sub-VI it will not inherit the properties of the indicator in the sub-VI, and the sub-VI will not act on it in any other way than serve the data to it.
If you want the sub-VI to set cell colors of the indicator in the caller you'll need to give the sub-VI a reference to that indicator.
Feed that reference into a property node in the sub-VI and set the properties as you now do for the indicator inside the sub-VI (unless you ever display that indicator you don't need it to do anything with the indicator inside it).
The procedure will be as follows; Right-click on the indicator in the caller VI and select create reference, right click on the reference and create a control, paste that control in the s
ub-VI, associate it with a terminal...and wire the reference you created in the caller to that terminal of the sub-VI...now in the sub-VI wire the control to a property node, and select the properties you want to set...).
Here's an example as well:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3ED1D56A4E034080020E74861&p_node=DZ53012&p_submitted=N&p_rank=&p_answer=&p_source=External
(3,328 Views)
Thanks for a great answer, but my indicator in my caller is in a cluster. I can now change the indicator if it's outside by itself, but in the cluster, the indicator doesn't change at all. Any idea?
(3,328 Views)
I've figured it out how to do it. Thanks, your answer was very helpful.
(3,328 Views)
