table hangs after carriage return in cell
During data entry into a table cell if I just enter a carriage rutrun into a cell then click on another cell the table is unusable. restarting the vi does not fix it. Any fix for this?
Message 1 of 16
(4,099 Views)
What version of LabVIEW are you using?  I got did a quick test in 8.5 and didn't seem to have an issue.  Can you post a VI that demonstrates your problem?
Message 2 of 16
(4,097 Views)
Put a table inside a while loop, when the vi is running click in a cell press carriage return then click on a different cell. I have tried this with 8.21 on windows 2000 and 8.5 on vista
Message 3 of 16
(4,095 Views)
I tried this on 8.5 running on XP SP2 and it doesn't seem to crash. Try the attached vi.  It will help if you can upload your vi.
Vikas
Message 4 of 16
(4,076 Views)
if you enable the multi-line input of your vi it will hang also
Message 5 of 16
(4,069 Views)
I am afraid it doesn't! See the VI..
Message 6 of 16
(4,064 Views)
Also, I dont have LV 8.2 but I have saved the vi for previous version if you want to check it running under 2000. Hope it helps.
Message 7 of 16
(4,060 Views)
It crashes when you use a carriage return without entering any data just the carraige return! Do this click on a cell hit carraige return click in a diferent cell
Message 8 of 16
(4,058 Views)
Sorry to say it still doesn't.  You may have other issues.. installation maybe? As Matthew said.. it helps if you post the VI you are having issues with.
Message 9 of 16
(4,049 Views)
both of your vi's crash, I see now that it only happens when I click back in the the first cell that i enterd the carraige return into
Message 10 of 16
(4,044 Views)
