table reset
I am attachiing the vi, let me know what did I miss. I think I applied all the changes you mentioned.
Rajnikant Singh
Iowa State University (Research Assistant)
Message 11 of 15
(2,655 Views)
Find attached modified code:
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 12 of 15
(2,645 Views)
great it is working, your vi had a minor error. case structure cases in acquire case had to be switched around. I have one more question, if clear button is in a different vi, then how would I use it's value to clear table contents, is using global variable in this case a good programming option. ?
Rajnikant Singh
Message 13 of 15
(2,639 Views)
Accepted by topic author raj_iastate
I will prefer 'dynamic event' generation over using a 'global variable'.
You may want to refer following links:
1. Nugget of the week: Dynamic event registration
2. Dynamically Registering Events
3. User Events
Message 14 of 15
(2,623 Views)
thanks for the time and effort you put into answering my question. It was great !!!
Rajnikant Singh
Message 15 of 15
(2,615 Views)
