table update
Hello I have table and 2 combox string. Once i start the VI  and change values in combox, the table shoudl also update simultaneously... Thanks for any help
Nghtcwrlr
(3,496 Views)
Hi Nghtcrwlr,
you cannot replace elements of an empty array! As long as the table is empty ReplaceArraySubset will not work...
(3,481 Views)
Then how is it possible to update an empty table?
Nghtcwrlr
(3,477 Views)
either define your table as 2D array of empty strings or use BuildArray instead of ReplaceArraySubset...
(3,470 Views)
ya-.. I created a 2D arraxy and then worjed a little bit with it to get the result. Thanks for the help
Nghtcwrlr
(3,458 Views)
