table
It sounds very similar to this post from a couple of days ago. Since a table is nothing more than a 2D array, the Array Size function will tell you how many rows and columns of data there are.
Message 11 of 13
(1,328 Views)
Thank you Dennis for your post. Since I was using the Build Table vi, it has a Reset input that I had not noticed. Using that instead of initializing the table (that automatically connected to it when it is placed on the block diagram), works! I simply "pulse" that Reset input on the zeroth (first) iteration of my while loop that is "collecting" the data.
Thanks again.
Message 12 of 13
(1,321 Views)
First you remove all the data from the table and insert 2D empty array to that,and make that empty is default data(By right clicking the table).
Message 13 of 13
(1,235 Views)
