table
I have a problem.
My program compiles a table. Although I activated "Autosize Row Height" I can not see all the contents of the table rows.
That is, in fact, the rows of the table set differently depending on the content, however, in those in which the content is larger than the text wraps without completing the sentence (leaving incomplete sentences)
Does anyone know what happens?
(3,353 Views)
Hi gmazza
The “Autosize Row Height” can only change the height of the column, but does not affect the width. You can change the column widths using a series of property nodes for the table.
First right-click on the table's terminal on the block diagram and select Create»Property Node»Active Cell»Active Cell, select “All to Write” and create either a constant or a control. This creates a cluster that tells LabVIEW which cell in the table it should use as the active cell.
Then right-click on the table's terminal on the block diagram and select Create»Property - Node»Active Cell»Cell Size»Width and wire a numeric constant or control to the input to set the width of the cell.
I give you an example how you can use it with the size of randomly table.
Have a nice day
Certified LabVIEW Architect (CLA)
(3,301 Views)
Hello Jean,
thanks for your response.
I can not see because I own Labview VI 11. However, I see what you mean and this is useful for me to define the size of the cells.
The problem is that the text inside the cell does not spread well. As soon as the space of the cell ends, the text does not wrap. Therefore you are unable to read.
Do you understand what is my problem?
(3,268 Views)
Hi Gmazza,
As I understood, the program created by Jean resolves you problem. I recommend upgrade your labview and see it.
Otherwise, I attach the screenshoots from the front panel and the block diagram. It could help you to create your own program.
Have a nice monday
(3,229 Views)
