table
Hi drek,
this looks like the correct function. just use it!
When you are unsure about functions: open the context help with Ctrl-H…
Message 11 of 50
(3,463 Views)
trying hard 🙂
Message 12 of 50
(3,457 Views)
this is what i already got
Message 13 of 50
(3,451 Views)
Hi drek,
why did you increase the ReplaceArraySubset for replacing two elements at once? Decrease it to just one element - the same as you use before the case structure!
You only need to follow my picture above…
Message 14 of 50
(3,441 Views)
sry for the late answer, because much work, made the vi like you told i guess , but nothing appaears at the table to what should i connect it ?
Many thanks in advantage
Message 15 of 50
(3,404 Views)
Hi drek,
when you want to replace certain elements in a 2D array you should provide a new value for these elements.
Right now your VI contains two ReplaceArraySubset functions, but you don't wire any new data to these functions. You should wire the value you want to put into the table…
Additionally your table is a control instead of an indicator - quite silly when you want to display values. And you did not wire anything to actually write data into the table control/indicator…
Message 16 of 50
(3,397 Views)
got this until now, value appears and dissappaers again
Message 17 of 50
(3,380 Views)
Hi drek,
I'm sorry, but when I open your VI it is broken due to a broken wire missing a datasource. You  still haven't wired the ReplaceArraySubset functions correctly!
LabVIEW also complains about missing subVIs…
As long as I cannot run your VI I cannot watch any values (dis)appear!
Message 18 of 50
(3,371 Views)
gonna make it again gorgot to save it damn 🙂 so must be better
Message 19 of 50
(3,360 Views)
What is supposed to happen when Boolean is False?  You are currently clearing the array (making it empty).  Once that happens, I'm not sure the Replace Array Subset will work (replacing an element that does not exist).
Message 20 of 50
(3,351 Views)
