table
Hi all.
        Is there any way to auto clear table? after 10mins interval. Thank You.
(3,802 Views)
Auto no.
See attachment for an idea.
Message Edited by Pnt on 12-02-2008 06:47 PM
(3,794 Views)
Hi Isabella,
This is another suggestion that you may want to consider.
Regards
Lee
NI ASEAN
(3,759 Views)
Thanks Lee for the diagram. I'm trying out now. (:
(3,730 Views)
Hi All,
        I currently trying to clear my data from my table. I put in the clear case structure, same as the clear graph.  Below attached screen shots of my program.
auto picture: what i put in my case structure.
auto 1 picture: when i press once, the graph will be clear. But the table wasnt clear, it shows false constant.
auto 2 picture: when i press the second time. the table able to clear.
I was wondering why the table cant clear it on the first attempt. Or thr's some portion i did it wrongly.
hopefully i'm explaining clear enough.
Isa
(3,724 Views)
Hi All,
thanks for reading and answering my doubts. Anyway, i solved my clearing by set the time target as 0. it will clear together with my graph.
Thank You.
Isa
(3,694 Views)
