tabs display incorrectly in string control
I posted this question before without a satisfactory answer(activex/dotnet is not stable enough) but cannot find the post so I'm posting it again.
I'm posting text information to the labview string control, but the data is not aligning properly. Is there a setting I can use so tabs will fill more than just a single space and allow text to line up properly?
Message 1 of 12
(5,820 Views)
To the best of my knowlege, NO.
Some work-arounds?
Hmmmm
Use the format into streadsheet string and use the tab as the delimter and display in a table with transparent cell lines?
Write code to insert the proper number of spaces to accomplish the foramtting.
Ben
Message 2 of 12
(5,810 Views)
It was here. I just clicked on your name to view the posts you had done. Was the second one on the list.
I would agree that the the table is your best bet. That's what I've done in the past.
Out of curiosity, what was unstable with the ActiveX/.NET solution? What did you actually use?
Message 3 of 12
(5,793 Views)
You can format your string using the Format Into String node.  I've made this to show how different length data in one column doesn't mess up the allignment of the other columns.  This won't work unless you use monospace fonts (I used Courier).
Jim
Message 4 of 12
(5,781 Views)
I love it when I'm wrong!
Just learned something new today thanks to you Jim.
Ben
PS You have been tagged
Message 5 of 12
(5,778 Views)
"Out of curiosity, what was unstable with the ActiveX/.NET solution? What did you actually use? Kudos! Thanks! Solution? "
First, I cannot access the text the same way I can with a normal string control. This requires me to update all instances. Putting that inconvenience aside, when I place the RichTextBox control in a custom type, it comes up in different positions when instatiated.
Message 6 of 12
(5,763 Views)
I've used Jim's approach in the past as well, but I never liked the magic numbering required for getting the columns lined up. And, if you try to save it to a spreadsheet file it's a bit cumbersome since you get all those spaces inserted to make things line up.
Message 7 of 12
(5,752 Views)
I'm having a similar issue.  I'm trying to display the output of an external binary file from within my LabVIEW program via a string indicator and tabs are not shown correctly so it looks like an absolute mess.
vs
Is there any new insight on the best approach for this problem since the last post?  Thanks you.
Message 8 of 12
(5,381 Views)
Can you display it in a table or multicolumn listbox.  Either would require a bit of preprocessing, but if the fields are tab separated, the Spreadsheet String to Array function should do what you need.
Lynn
Message 9 of 12
(5,371 Views)
Thanks for the reply.  There is other header/footer information in the output that does not conform to a table very well....
I also would like it if my Input File string control accepted "tabs" as input in case my users want to modify the source code before passing it to the executable for processing.
I think a .NET or ActiveX control may be my best bet for this.  Any recommendations?  I'd love to use Notepad++ but there doesn't appear to be any .NET or ActiveX hooks.
Message 10 of 12
(5,367 Views)
