tabs in front panel
Hi everyone,
can someone please tell me how I can make "tabs" in LABView 7.1.1 in the front panel so that I have options of displaying different graphs from different channels on different levels so that I can click through the "tabs" to display the wanted info?
Thank you
Best regards
Charel Marais
(2,969 Views)
Hi Charel,
If you right click on the front panel of your vi you should get a pop up of the controls palette or go to the "Windows" top menu and select "Show Controls Palette". In the middle of the controls palette is a sub palette labeled "Containers" and the first item listed is the "Tab"  control. There also is a "Dialog Tab Control" listed under the "Dialog Controls" sub palette.
hope this helps
cheers,
--Russ
(2,965 Views)
Hi Russ,
Thanks for the reply, was what I was looking for. Didnt know what the things were called or that "tabs" would be found in "containers"!!!
Thanks again!
Cheers
Charel
(2,961 Views)
