tagsrv.exe is using 100% of my CPU
Several times since installing LV 8.5, I have noticed that something called tagsrv.exe has gone nuts and started consuming 100% of available CPU cycles.  In every case, I was not even running LabVIEW!
Is this a known issue?
Will it happen on my customers' computers where I have installed LV applications?  (They won't be happy.)
-GN
(4,838 Views)
check this
(4,831 Views)
I think it wont happen on the customer's PCs, unless & until it has/runs only the application[exe].
If you happen to install LV or any related stuff like DSC, the tagsrv.exe may again start to be problematic.
- Partha ( CLD until Oct 2027 🙂 )
(4,816 Views)
