taking mean at runtime
hey!!
how can i take the mean of values coming at runtime ,should i have to save them and read from the file at runtime again and again?
plz help tnx
Message 1 of 14
(9,650 Views)
Could you please explain more in detail what you are trying to do ?
Message 2 of 14
(9,639 Views)
Well, if you have an array of values, simply use te built-in mean function, If the data is coming in one point at a time, there is a "point-by-point" version of the mean that calculates a running average over time - in fact building such a thing used to be an exercise in the LV Basics course.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 14
(9,632 Views)
can u guys pls tell me where i can find this point by point mean function .
I am new to LV
tnx.
Message 4 of 14
(9,614 Views)
Right click on open space in the block diagram and select the following series of menus:
Functions / Analysis / Point By Point / Probability and Statistics PtByPt
They are all in there...
LabVIEW Champion
Message 5 of 14
(9,603 Views)
I would highly recommend you to take LabVIEW courses. More information about the courses can be found at LabVIEW Courses.
Adnan Zafar
Coleman Technologies
Message 6 of 14
(9,592 Views)
Absolutely! Plus, but if I remember right from the last time I looked at the LV Basics class materials a point-by-point average VI is one of the first things that they have you build.
Mike...
LabVIEW Champion
Message 7 of 14
(9,585 Views)
Hi ssddii
In case you can´t take the course right now and you need to solve your problem now, I've attached an example on how to average values coming at runtime. I hope this helps you.
Robst.
Message Edited by Robst on 05-11-2007 10:44 AM
Robst - CLD
Using LabVIEW since version 7.0
Message 8 of 14
(9,569 Views)
If you just want the mean of all values acquired so far, just keep the sum in a shift register and divide by the count. 🙂
Here is a simple example:
Message Edited by altenbach on 05-11-2007 08:48 AM
Message 9 of 14
(9,566 Views)
Hello:
Actually altenbach's example is simpler, I just complicated myself doing all that logic with the iterations counter and the other stuff Smiley Tongue
Sorry, I made it quickly, but the idea is the same Smiley Wink
Robst - CLD
Message 10 of 14
(9,554 Views)
