task setup files
When I create a task using VI Logger 2.0, are there any files created anywhere outside of the actual program?  I'm not looking for the actual data aquired from the logger, just the setup files if there are any.  My goal is to eventually have the program run a certain task automatically when the program is opened.
(2,874 Views)
bambim,
The configuration settings are contained in files external to the VI Logger application.  These settings are actually stored in several files in the MAX directory.  As far as your eventual goal, I am not sure if these files would help you get it to start automatically anyway.  I am not sure off the top of my head if there is a good way to get this to happen.  If I find anything out I will post the idea to the thread.
Neil S.
Message Edited by Neil S. on 07-10-2006 06:22 PM
(2,846 Views)
