tcp data b/w labview and c++
Hi
 i am trying to establish TCP connection b/w LABVIEW and C++ program. Server is established in C++ while client is implemented in labview.Although connection is successfully establish b/w server and client, both are unable to correctly understand data send/receive among them. Forexample if i want to send an int type send_array from server, i use standard WINSOCK function "send" like that:
send(AcceptSocket,(char*)send_array,129*4,0);
but when client in labview receive this array, it shows unexpected values.As a client, I used "simple data client.vi"  with one modification i.e. as sent data size(129*4 bytes) was fixed, only one TCP read was used .
Same problem exists if i send data from client to server.
Kindly help me
Best Regards
(4,109 Views)
Accepted by topic author ASIM_BHATTI
It's probably an big/little edian problem. If you are using the Flatten/Unflatten from String functions, you can specify which to use.
(4,100 Views)
I have the same problem.
Do you have the solution?
thanks
(3,853 Views)
thanks
Did you read the post from Dennis which is even marked as solution? As short as it is it does provide all information that is needed for the solution of the problem the OP had!
Rolf Kalbermatter  My Blog
(3,831 Views)
It has been long since this problem occured. I think "little indian/big indian" was the issue in my case which was finally solved
Thanks & Regards
asim
(3,793 Views)
