tcp/ip timeout problem- client/server
Hi MSD100,
can you maybe attach a picture of your vi's? Currently i have only LV8.5.
Did you try this example http://forums.ni.com/t5/LabVIEW/tcp-ip-timeout-problem-client-server/m-p/1413074#M548288?
This example can be stopped without a connection. Can you please explain why this isn't working for you?
Try to help
Mike
Message 21 of 25
(1,794 Views)
hi mike !
i have tried your suggestion...but there must be something missing on my side...
I am attaching for 8.5 version.
can you see it?
Message 22 of 25
(1,785 Views)
Hi MSD100,
yes thanks, i got it.
The reason it doesn't work for you was, that the refnum you want to close was connected after the "TCP Wait on Listener". Because of the data flow the "TCP Close" function could not run.
See the attached example, it should work for you.
Mike
Message 23 of 25
(1,783 Views)
I forgot to attached the revised version.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 24 of 25
(1,765 Views)
Here is a mdified version that allows for bidirectional communication between the client and the server. In addition, the server will remain running and accepting new connections after a client disconnects.
Mark Yedinak
LabVIEW Champion
Message 25 of 25
(1,735 Views)
