tcp/ip
hello,
      i have created client and server program, both i am running in same pc with same ip address and port no.
it is working fine but tcp/ip is connection orineted service if i remove LAN cable still it is transfereing data. then what is wrong with that.can any one please help me.
Message 1 of 11
(5,599 Views)
If it is same PC then what does LAN matters.What IP address you are using?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 11
(5,598 Views)
if it is 127.0.0.1 then It will like this only
--Ranjeet
Message 3 of 11
(5,597 Views)
no it is 192.168.1.92                 and for this loop back is working or not.
Message 4 of 11
(5,590 Views)
What does it mean? You are telling or asking?
--Ranjeet
Message 5 of 11
(5,584 Views)
hello sir,
               hello sir i am asking .
Message 6 of 11
(5,582 Views)
This might possible it is communicating with self only as we cannot tell without seeing your VI.. Do one thing there are lots of 3rd party software which will send data over TCP to particular IP address(Make sure you are not is same network). Use this software and then read through lablivew.
This will verify your VI.
--Ranjeet
Message 7 of 11
(5,575 Views)
hello sir .
        i have attached my vi's. client and server respectively.
Message 8 of 11
(5,570 Views)
Can you upoload in 2011 format
--Ranjeet
Message 9 of 11
(5,565 Views)
hello sir.
    2011 format.
Message 10 of 11
(5,559 Views)
