tcspc
Hi
Do anybody familiar with the VIs of TCSPC card ( Becker-Hickel)
Eruvi
(4,607 Views)
I have written some code using one.
Message Edited by rpursley8 on 01-24-2006 10:49 AM
Randall Pursley
(4,598 Views)
Hi Randall
I have their labview library, but the manual is so bad and I need more help in order to understand how to use these VIs. Could you please send me an example ?
My aim is to use scan mode of the SPC card...
Thank you in advance
Eruvi
(4,589 Views)
I don't think anything I send you will help much.  I have integrated some of the functions into a larger program.  I did try out the scan function at one time and found it to be cumbersome so I went another direction and just used the card as single point acquisition.
What is your application?
Randall Pursley
(4,581 Views)
I am using optic scanner and I want to acquire 2D lifetime map.
I wish that labview will conrol and synchronize between them.
But you are right maybe it's will be  easier to use the card as single point acquisition.....
still ,I need more detailed manual in order to don't cause demage to my card settings...
Eruvi
(4,579 Views)
We are doing lifetime fluorescence using a laser as a source.  Attached is the ini file with the settings we use.
Randall Pursley
(4,578 Views)
Hi all,
I am developing a Labview module for our TCSPC laser microscope, i wanted to acquire X-Y images in Scan Sync In Mode via labview. I have their Labview library but am unable to develop such a function from it. We used to do this via SPC-830 software that they provide but now want to integrate the whole system (motion, image acquisition and image analysis) together in labview. If anyone of you has done something related, let me know. Also if you can offer any advice, that would be priceless,
- Thanks a lot,
Muttee Sheikh,
Photonics Research Group,
Dept. of Electrical and Computer Engineering,
University of Toronto,
Canada
muttee.sheikh@utoronto.ca
(4,298 Views)
