tdc001 thorlabs
Are you using a translational stage. If so, are you homing it?
You are also using the moveAbsolute function in your code, without ever setting an absolute position. See the atatche dsnippet for setting an absolutePosition.
Message 41 of 44
(1,280 Views)
were you able to get kinesis error rectified in the .NET container?
Message 42 of 44
(1,034 Views)
Hi
I am attempting to control a TDC001 motor to switch directions too,but the motor is failing to switch directions. Do you have any idea why this is happening? I think it has something to do with the way I am setting the velocity parameters for the jog. I have tried multiple different things just like sent the value "0'' or ''1'' to the port of ''Ijogdir'' but cannot fix the directional issue.
I hope to get your help,thank you!
Message 43 of 44
(814 Views)
oh~I got it.It should be "1" and "2".
Message 44 of 44
(792 Views)
