tdms does not support complex numbers?
I can see that I can create and manipulate complex waveforms in Labview, but when I try to save such a waveform in a TDMS file, I get a run-time error that data format is not supported, forcing me to split the complex waveform into two separate waveforms for saving.
Also, when I send a complex waveform to a Waveform Graph indicator, it truncates the imaginary part.
Are there any plans to add native support for complex numbers in TDMS and graphing?
(3,342 Views)
That's correct. TDMS does not support complex values.
That's also correct. Think about it. What would you plot on a waveform graph? You could use something like an XY graph, with X being the real values and Y being the imaginary values. Or, you could use a polar plot (available as a picture indicator plot).
If you wish to make a suggestion regarding this, then you can post in the LabVIEW Idea Exchange, where people can vote on the idea. You may need to submit this as two different ideas since it's covering two different components.
(3,335 Views)
I guess, since it's a Waveform Graph, plot two traces, Re and Im, as a function of time.
(3,317 Views)
