tdms error -2147319779
I am currently attempting to edit a TDMS file and make it a excel file. I am getting error-2147319779  saying that the error "occurred at Library not registered.". Does anyone know how to fix this?
(4,108 Views)
will be good to debug if you share the file too.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,078 Views)
I actually managed to make my script run with no errors, but now I am confused as to why my script wont produce an excel file in addition to my TDMS file. Any idea why that is?
Mmoon
(4,062 Views)
