tdms excel
Can you attach a small example of your tdms data which shows this problem - I'd like to reproduce it if possible!
JLS
Best,
JLS
Sixclear
Message 11 of 16
(2,019 Views)
I get Unknown error 0X80020009 when ever I try to load the TDMS file with the ExcelTDM.dll. No data loads. Is anyone working on this or am I only luck one that is still having problems?
Message 12 of 16
(1,893 Views)
Hi Everyone,
I have been using the TDM Excel Add-in version 1.1.10 extensively with Excel 2003 and a little with Excel 2007, and I have had no problems loading TDM or TDMS files.  If you have trouble loading a particular file into Excel, please attach the TDM or TDMS file(s) to your Discussion Forum post.  The R&D group responsible for the TDM Excel Add-in has been HIGHLY responsive to bugs reported thus far, and fixes to the TDM Excel Add-in often appear on the web in a matter of a week or two after you send us the file that gives you trouble.
So far I do not see any attached data files to this Discussion Forum thread, so there's very little I can do to help the two or three folks on it who have reported trouble.  Any file that does not load correctly should be reported as a potential bug in the TDM Excel Add-in.  It is true that Excel 2007 only imports up to a million rows and earlier Excel versions import only up to 65,000 rows, but in both cases the TDM Excel Add-in will ask you WHICH subset of rows you want to load and then load that subset correctly-- this should not cause an error message or incorrect values.
Brad Turpin
Message 13 of 16
(1,885 Views)
Hi Brad,
I've got one for you, but it is real data and a lot (tdms of 50 MB, zipped 35) of data.
Can I contact you directly to discuss this?
Ton
My LabVIEW Ideas
Message 14 of 16
(1,873 Views)
Hi Ton,
Before you send it in, try renaming the TDMS file with only standard alphabetic and numeric characters.  R&D just got done fixing a bug with the TDM Excel Add-in where it does not clean the worksheet name enough that it takes from the file name-- Excel apparently has quite a few character limitations in the worksheet name.  If renaming your file fixes the problem, then we have a new verrsion of the TDM Excel Add-in (which will be posted soon) which will happily load your remaining files.  If renaming does not fix your loading problem, then definitely post your huge data file to ftp.ni.com/incoming and send me an email at brad.turpin@ni.com to let me know it's there.
Note that if you have a TDM file, you need to rename it interactively in DIAdem or programmatically in LabVIEW-- just changing the names of the TDM and/or TDX files in Windows Explorer will render the file unreadable by all applications.
Brad Turpin
Message 15 of 16
(1,867 Views)
Hi Brad,
My file name is voltage.tmds, that should be simple enough. There are 4 channels from a PCI-4462 created with SignalExpress in data loging mode. Just as simple as I can make it. I have tried to load 20 different files and have yet to load one that works. All the files are created the same way with the same names.
John
Message 16 of 16
(1,845 Views)
