10-11-2006 09:03 AM
Can you attach a small example of your tdms data which shows this problem - I'd like to reproduce it if possible!
JLS
05-15-2007 06:31 PM
05-15-2007 11:40 PM
05-16-2007 03:21 AM
05-16-2007 08:44 AM
Hi Ton,
Before you send it in, try renaming the TDMS file with only standard alphabetic and numeric characters. R&D just got done fixing a bug with the TDM Excel Add-in where it does not clean the worksheet name enough that it takes from the file name-- Excel apparently has quite a few character limitations in the worksheet name. If renaming your file fixes the problem, then we have a new verrsion of the TDM Excel Add-in (which will be posted soon) which will happily load your remaining files. If renaming does not fix your loading problem, then definitely post your huge data file to ftp.ni.com/incoming and send me an email at brad.turpin@ni.com to let me know it's there.
Note that if you have a TDM file, you need to rename it interactively in DIAdem or programmatically in LabVIEW-- just changing the names of the TDM and/or TDX files in Windows Explorer will render the file unreadable by all applications.
Brad Turpin
DIAdem Product Support Engineer
05-16-2007 10:49 AM
