tdms file viewer graph layout
I am taking multiple inputs from a BNC 2120 using the DAQ assistant and viewing them through a TDMS file viewer on output.
The graphs that i get in the tdms file viewer shows all the signals on the same graph. The way i need them is to be on seperate graphs so that i can perform a more precise analysis of the signals.
(2,990 Views)
The TDMS viewer is has the source code available.  Feel free to make a copy of your own and edit it how you like.  Alternatively check out Scout which is a more full featured TDMS viewer.
(2,963 Views)
In TDMS File Viewer, the graph displays signals depending on your selection, if a group is selected all the channels under this group will be displayed in the graph; If you want to display only one signal at a time, you should only select the specified channel.
(2,944 Views)
