tdms_index pitfall
last week I had to hunt down a strange bug in a LabVIEW app.
The usecase looks about like this.
The user can create a table with setpoint values in a small editor. As fileformat for this we choose TDMS-files with a waveform in it.
A host application transfers the file to a RT system (since all documentation calls the tdms_index files optional, we do not copy them). The RT app reads the wfm and uses the values for a motion control task.
So far so good a simple mechanism for a simple problem... but... a strange behaviour happened. _Sometimes_ the wfm weren´t completely read out of the TDMS file.
What happened is the following:
The user made a file (e.g. named "file1.tdms") with a wfm-length of 100 points. Transfered it to the RT (only the tdms file get´s copied) and starts the control task. At this point the TDMS-file functions recreated the tdms_index when reading the file for the first time. Then the user decides to alter the wfm in his editor on the host, creating a new one with a wfm-length of 1000 points saved under the same filename (file1.tdms). This file gets again transfered and read in by the RT app. But now the TDMS-file read returns only a wfm with 100 points!
The problem is the tdms_index file from the first read operation. It only knows about a "file1.tdms" with a wfm with 100 points. It looks like the TDMS function only use the filename to decide if and which _index should be used. No other check seem to involved!?!
Our quick and dirty workaround now is to try deleting the _index files before every load.
The attached VI shows the same behaviour under LabVIEW 8.5.1 Windows.
crosspost in LAVA: tdms_index pitfall
(3,745 Views)
Good catch,
The only solution I can think of is to delete the index file when you copy a new tdms file, or include the accompanying index file.
Does this happen on Windows as well?
Ton
My LabVIEW Ideas
(3,723 Views)
yes this does happen on Windows as well. Just tested it with the LV 8.6... same symptom.
(3,713 Views)
