tdms read
hi,
I want to trace the data of an acquisition, I have 6 parameters, that's why I want to give the user to choose which signals are traced using a list box.
it works but I have the right to only one choice just before the end of the acquisition but after that even if I change my box list choice I don't trace anything? I want the chosen user after the end of the acquisition to have the signal traced and to be able to change it as they wish?
how can I correct this?
THANKS
(1,319 Views)
Hi Amelie,
What I can tell from your two truncated images of some code is: you forgot to THINK DATAFLOW!
  • How is the "event" image related to the "data" image? They refer to differently controls/indicators…
  • The control "channel names in" is read only once, probably long before the Acquisition loop is running… (THINK DATAFLOW!)
(1,316 Views)
hi ,
how can I correct this problem, I want to read my listbox after acquisition?
and I also want to have the possibility to change my choice while the program is running?
thanks in advance
(1,263 Views)
Hi Amelie,
As written before: most probably you need to THINK DATAFLOW!
(Unfortunately you still forgot to attach code…)
(1,255 Views)
