tdms
Hi all,
I am relatively new with labview. I had an accelerometer (3-axis) and I wanted to measure vubrations. I used the attached vi and the resulted file was the attached one.
I now want to review the data.Do you think I will be able to view the data from each channel (x-y-z axis)?
Thank you in advance!
(2,456 Views)
You might consider this example TDMS file player / TDMS recorder http://zone.ni.com/devzone/cda/epd/p/id/6354
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(2,450 Views)
