tdms
I have Problem regarding filter data from TDMS file.
I want to make This type of report as shown in figger.
pleas give me directions to do this.
(3,491 Views)
What does the data in the file look like? What are you wanting to filter?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,468 Views)
TDMS is likely not the file format you want to make a report like that.  Use the Report Generation Toolkit which can call into Excel to make spreadsheet files.
(3,456 Views)
The TDMS addon for Excell won't quite create pivot tables but, it certainly does permit you to filter groups and channels and allows you to position channels in any column order you wish.  Just hit the configure TDMS button.
(3,450 Views)
