I would like to acquire a waveform with a tds3034 scope. I need to trigger the scope using a further signal, I read with channel 2. I also would like to acquire as average, to have bigger resolution. Sometimes I get the error: Driver status Hex0xBFFF0015 and Primary error Hex 0xBFFA2003 What does this mean? Afterwards I cannot acquire anything else. I have to restart Labview. What could I do?
1) What type of communication you are using: GPIB or serial? 2) Can you sometimes make trigger and read wfrm? 3) To make averaging you need write command: ACQUIRE:MODE AVERAGE; NUMAVG 512 (for example); this command make averaging in all channels. 4) To make trigger with ch2 write command TRigger:Source:CH2;
Hi, thanks. I know my question was not very clear. 1) I use GPIB to communicate 2) What I do is to use some of the given drivers for my instrument (Labview version 6.1) with IVI.: so I can set the channel to acquire and the triggering channel. When I acquire in "sample" I get no problem (at least apparently, I'm still working with "artificial" signal given by a frewquency generator). The problem (and the error) appear when i try to increse the number of averages: up to 8 seems to be ok. Then I get the error.
I don't know about these drivers. But maybe this driver have 2 vi's: first is selecting of Acquire Mode: Sample, Average, Envelop. After that you select Average, there is another vi that say how many averages to do.
I think that the latter is the cause. But I don't know how to solve the problem. I use the averaged signal also to trigger the oscilloscope. alessandra
