hello,
I recently migrated to the labview8 environment from 7.1. A program that was originally written in labview7.1 for the tds744a o-scope (over GPIB)
has been quite problematic in labview 8. The issue is the setting of the vertical scale for the individual channels particulary the first three channel when a 10x probe is attached. A limit of 1V/div is allowed under labview8. This has not been a problem under labview7.1. Appreciate any suggestions. Thanks.
