tektronix 3032B
I am controlling the tektronix 3032B scope by the Labview "Tektronix TDS 3000 Series Single Channel Waveform Acquire" by Natioanl instrument.  But the waveform is in cluster form. How do I save it into file? Please suggest. Thanks
(3,691 Views)
Build waveform and then build array and you can use save waveform or write to file vis.
uday
(3,662 Views)
LabVIEW has a data type called "Waveform". I'm assuming this is what you have.
There are specific VIs to interact with this data type.
They are located on the Programming Pallette -> Waveform
Under: "Wfm File I/O" you will find "Write Waveforms to File.vi"
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,651 Views)
Hi!
I have tried your suggestion, however, there was problem in wiring.  The data type mismatched between the terminals.  Attached are the tektronix zip file and screen shot.  Upon unzip, the file "Tektronix TDS 3000 Series Transfer Current Waveform Example.vi" which I am using can be found under "Tektronix TDS 3000 Series\Examples" directory.
(3,598 Views)
Accepted by topic author surjendu
(3,583 Views)
