telnet data out
I am having a problem with the telnet read data out, i am getting with the wanted output also many other characters, is there any way to filter those?
example:
    [1;1HMicrosoft Windows XP [Version 5.1.2600] [2;1H(C) Copyright 1985-2001 Microsoft Corp. [4;1HC:\Documents and Settings\bmulab\Desktop> [4;42H [4;44H [4;1HC:\Documents and Settings\bmulab\Desktop>cd C:\Documents and Settings\bmulab\Des [5;1Hktop\nic [6;1H [4;45H [7;1H [4;46H [7;1H [7;1HC:\Documents and Settings\bmulab\Desktop\nic> [4;47H [7;46H [4;48H [7;46H [4;49H [7;46H [4;50H [7;46H [4;51H [7;46H [4;52H [7;46H [4;53H [7;46H [4;54H [7;46H [4;55H [7;46H [4;56H [7;46H [4;57H [7;46H [4;58H [7;46H [4;59H [7;46H [4;60H [7;46H [4;61H [7;46H [4;62H [7;46H [4;63H [7;46H [4;64H [7;46H [4;65H [7;46H [4;66H [7;46H [4;67H [7;46H [4;68H [7;46H [4;69H [7;46H [4;70H [7;46H [4;71H [7;46H [4;72H [7;46H [4;73H [7;46H [4;74H [7;46H [4;75H [7;46H [4;76H [7;46H [4;77H [7;46H [4;78H [7;46H [4;79H [7;46H [4;80H [7;46H [5;1H [7;46H [5;2H [7;46H [5;3H [7;46H [5;4H [7;46H [5;5H [7;46H [5;6H [7;46H [5;7H [7;46H [5;8H [7;46H [5;9H [5;1H [6;1H [7;46H [7;48H [7;1HC:\Documents and Settings\bmulab\Desktop\nic>Disable_NIC.exe [8;1H [7;49H [8;1H [7;50H [8;1H [7;51H [8;1H [7;52H [8;1H [9;1HC:\Documents and Settings\bmulab\Desktop\nic> [7;53H [9;46H [7;54H [9;46H [7;55H [9;46H [7;56H [9;46H [7;57H [9;46H [7;58H [9;46H [7;59H [9;46H [7;60H [9;46H [7;61H [7;1H [8;1H [9;46H [9;48H [9;1HC:\Documents and Settings\bmulab\Desktop\nic>cd C:\Documents and Settings\bmulab [10;1H\Desktop\nic [11;1H [9;49H [12;1H [9;50H [12;46H [12;1HC:\Documents and Settings\bmulab\Desktop\nic> [9;51H [12;46H [9;52H [12;46H [9;53H [12;46H [9;54H [12;46H [9;55H [12;46H [9;56H [12;46H [9;57H [12;46H [9;58H [12;46H [9;59H [12;46H [9;60H [12;46H [9;61H [12;46H [9;62H [12;46H [9;63H [12;46H [9;64H [12;46H [9;65H [12;46H [9;66H [12;46H [9;67H [12;46H [9;68H [12;46H [9;69H [12;46H [9;70H [12;46H [9;71H [12;46H [9;72H [12;46H [9;73H [12;46H [9;74H [12;46H [9;75H [12;46H [9;76H [12;46H [9;77H [12;46H [9;78H [12;46H [9;79H [12;46H [9;80H [12;46H [10;1H [12;46H [10;2H [12;46H [10;3H [12;46H [10;4H [12;46H [10;5H [12;46H [10;6H [12;46H [10;7H [12;46H [10;8H [12;46H [10;9H [12;46H [10;10H [12;46H [10;11H [12;46H [10;12H [12;46H [10;13H [10;1H [11;1H [12;46H [12;48H [12;1HC:\Documents and Settings\bmulab\Desktop\nic>Enable_NIC.exe [13;1H [12;49H [13;1H [12;50H [14;46H [14;1HC:\Documents and Settings\bmulab\Desktop\nic> [12;51H [14;46H [12;52H [14;46H [12;53H [14;46H [12;54H [14;46H [12;55H [14;46H [12;56H [14;46H [12;57H [14;46H [12;58H [14;46H [12;59H [14;46H [12;60H [12;1H [13;1H [14;46H"
Thanks.
(3,141 Views)
Hi Alvarion_Israel,
which charachters do you want to filter out?
Mike
(3,139 Views)
found the way.......its
\[[0-9]+;[0-9]+H   the serach and replac...
Thanks any way
(3,130 Views)
