temperature control using USB-6009(AO)/USB-9211A(AI)
I need a temperature control code. such as increase AI0 0-10V DC voltage (USB-9211A) to 600 degree with a rate of 5degree/min and stay there for 1 hour. AO0(USB-6009) gives out 0-5V DC voltage 1mA to control it. Could you write for me an example code?
I am using Cont Acq Thermocouples Sample-Int Clk.vi from labview 8.6 AI examples. I have a USB 9211A. It works fine. But I really have no clue on the system control. Thank you so much
(3,732 Views)
Nobody over here is going to 'write' the code for you. I would suggest you contact an alliance member of National Instruments for help.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,725 Views)
At least showing some hints or similar examples of this slow heating rate control problem
thank you
(3,715 Views)
It is an add-on. more about it here http://sine.ni.com/nips/cds/view/p/lang/en/nid/1394
Also try google and "pid labview"
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,698 Views)
