temperature measurement
Built an VI that continuously measures the temperature once per second and displays the temperature on a chart in scope mode. If the temperature goes above or below the present limits, the VI turns on a front panel LED. the chart should plot the temperature, as well as the upper and lower temperature limits from the front panel. The VI front panel should also include controls to vary the amplitute of the signal generated.
(2,585 Views)
We are not here to build the code for you. Please go ahead and implement what you have described and if you face any issues, let us know. There is a lot of help online to learn LabVIEW as well. Here is one portal:
http://www.ni.com/academic/labview_training/
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,582 Views)
