temperature verification , one channel or 32 chan., does each chan. need calibra
National Instruments SCXI-1001 12-Bay modular chassis Qty: 2 chassis Each of the two N.I. chassis contains the following: N.I. SCXI-1600 16-Bit Digitizer for USB Qty: 1 digitizer module N.I. SCXI-1102 32-Channel T/C Amplifier Qty: 2 T/C amplifiers N.I. SCXI-1303 32-Chan CJC-compensated Direct-Mount Terminal Block Qty: 2 terminal blocks N.I. TBX-1303 32-Chan CJC-compensated Remote Terminal Block Qty: 2 remote terminal blocks When calibrating/verification of this system for reading temperature do I have to do each channel or all 32 channels or just 1 channel in each bank?
(2,778 Views)
Hi bmlservices,
How are you calibrating your modules? Are you following this document?
Thank you for choosing National Instruments.
Aaron Pena
http://www.ni.com/support
(2,761 Views)
actually I was just trying to verify temperatures to within +/- 1 C using labview software. kinda of a quick check thing.
(2,755 Views)
Hi bmlservices,
In that case, you may also need to take into consideration the accuracy and sensitivity of the data acquisition device you are using (i.e. SCXI-1600) and the V/degree C specification for the thermocouple you are using.
Aaron Pena
(2,741 Views)
