temps de changement
Munna! it doesn't work!! 😕
the table record every modification! not only a specific element (1,2)
also! can the 2 D table be an indicator! cause it's a databade indicator!
Message 11 of 18
(1,730 Views)
As I told you,  where your creating Event??
And,  don't create inner  While loop when your using Event structures
Munna
Message 12 of 18
(1,723 Views)
hi!
am I on the right road?
Message 13 of 18
(1,703 Views)
No.
Please let us know what you want to do exactly.
Munna
Message 14 of 18
(1,692 Views)
l want to read a table from a database(table2), then it records every modification in a specefic element in that table (0,1) for example! meanwhile, it records the time delay between two successive modifications!
is it clear?
Message 15 of 18
(1,681 Views)
How it will change? User will enter the Data at Runtime (or) everytime Database will change?
Munna
Message 16 of 18
(1,673 Views)
the user enter date from the database!
i tried something else (attached vi) but the column of time show me strange numbers!!
Message 17 of 18
(1,665 Views)
Check this.
1st read your Data Base and pass it to your Table2. there you can change the List.
Munna
Message 18 of 18
(1,650 Views)
