tension
Hi everybody
I need help to measure tension , can anyone give me simple example about it , ??
thanks
(2,946 Views)
(2,942 Views)
A simple example for measuring surface tension is the use of a Wilhelmy Plate.
(2,931 Views)
hi everybody
I am using chatillon/ dfs to measure force ( tension),  I have succeeded to conect with device and get data
I used n, x, X commands to read force and distance as I read in device manual
the problem is when I use n command , it give me two readings of distance then force like that :-
o.5 in
0.6 in
  0.3 lb
sometime give me 3 readings of distance and then force like that:-
o.5 in
0.6 in
0.7 in
 0.3 lb
sometime the data is cut in the middle
that mean n command did not give me organize readings , I can not using it to get max , min data
when I used X command to get only force readings,  there was delay , I get 18 reading per second while n command give me more than 40 reading per second that what I need
is there any one have experiance to work with this device or have information about chatillon commands
thanks
Suhad
(2,907 Views)
