terminate 3th party application
Hi Forum,
I use a third party application (C+, no source) and a labview application in my test setup. Sometimes this C program does not work well. In this case the Labview application terminates and restarts it. In 99% of the cases it works well as a workaround. Unfortunately rarely the Win XPSP2 pops up a window with a question about sending info to microsoft or not about the program error at the C program. This popup waits user interaction and the C program does not cleares off from the task list.
Any suggestion? I want to kill this C application automatically without user.
(LV7.1)
Regards
Tomi
(2,557 Views)
Are you referring to the automatic error reporting dialog that pops up? If so, you disable that from the System control panel. See here for explicit instructions.
(2,545 Views)
Many thanks.
Tomi
(2,524 Views)
