terminate state machine
Attachment is the simple state machine i did and for ur better understanding.
I have a state machine and which initially is at case "wait". After pressed the start button, it go to case "First" which sum the values and then got to case "Second" which subtract the values. And it will back to the wait again.
Wait i wish to is
1) I wish the state machine to stop after the case "Second" or after subtract the 2 values and switch on the LED (2nd Sequence) in the second flat sequence frame.
2) I only want the loop to run for one time only and do not repeat.
Thanks for ur help and time or reading.
Message 1 of 9
(5,003 Views)
Just send a TRUE to Loop Contition
Message 2 of 9
(4,996 Views)
see the attached one. Is this what u want?
Mathan
Message 3 of 9
(4,990 Views)
LOLz, tat easy.
Thanks ya.
Message 4 of 9
(4,985 Views)
Hi Mathan,
Is it possible to save the VI in labview 8.0 version
To Pnt,
I don think the way u suggest works. Or maybe i have some mistake.
I added a TRUE to stop the loop but it did not stop and continue back.
Thanks.
Message 5 of 9
(4,973 Views)
neiviv wrote:
Hi Mathan,
You don't need it. Pnt's solution is better because it does not use local variables.
Are you using the "continuous run" button to run the VI???   Don't!
Use the plain Run button!.
Message 6 of 9
(4,952 Views)
icic. Thanks for ur explanation. Its my mistake.
Thanks you or the help.
Message 7 of 9
(4,944 Views)
wrong message..
just ignore..
Message Edited by Pnt on 04-26-2008 01:00 AM
Message 8 of 9
(4,910 Views)
Hai,
Here is what u asked in LV 8.0
Mathan
Message 9 of 9
(4,853 Views)
